(#11)
(#12)
| Junior Member Posts: 17 Join Date: Feb 2009 | Quote:
Thierry | |
(#13)
| Junior Member Posts: 9 Join Date: Mar 2009 | If you want to avoid the usage of an inverter but wish to keep things as power efficient as possible, check out a dc-dc regulator. I have one of these and have used it on some car PC projects and it works great. http://store.mp3car.com/Carnetix_CNX_P2 ... wr-026.htm It works at 12v, 18.5v or 20v. I believe I read that the mini will function on 19v +/- 1v so this should work well. You would just need to either hack the tip off of your dell mini ac adapter or go find a usable tip at radio shack and solder it to some wire and into the outputs of the regulator. |
(#14)
| Member Posts: 70 Join Date: Mar 2009 | Do you think this one would work? http://cgi.ebay.com/CAR-UNIVERSAL-LA...QQcmdZViewItem |
(#15)
| Junior Member Posts: 26 Join Date: Dec 2008 Location: Malaysia | Quote:
(#16)
(#17)
(#18)
(#19)
| Member Posts: 52 Join Date: Apr 2009 | Quote:
your 4kw inverter might not be enough !!! hehe!!!! j/k | |
(#20)
| Member Posts: 79 Join Date: Mar 2009 Location: Austin, Tx | These guys have one http://www.allfreeship.com/shopexd.asp?id=2594&bc=no I do not have it myself, but I have ordered through these guys and got what I ordered. Just in case you are worried about ordering through them (a bit unknown). Windows 7 / LinuxMint |
