(#4)
(#5)
| Senior Member Posts: 208 Join Date: Feb 2009 | blah. that sucks. ah well. thanks for clearing things up for me! ![]() |
(#6)
| Super Moderator Posts: 5,774 Join Date: Nov 2008 Location: New Hampshire | Installing from the USB drive does not write to it. It sounded as if you had somehow installed Windows onto the USB drive and were booting the installed OS from it. That would be a good trick since generally Windows refuses to install onto or run from a removable drive. Mini 9|2GB RAM|64GB RunCore|Intel 5300|Windows 8 |
(#7)
(#8)
| Expert Member Posts: 692 Join Date: Mar 2009 | Can't you just use the built-in OS tools to mark the root directory of the drive as not writable? Mini2: Mini9, Black, 2G, 0.3 Webcam, Bluetooth, 32G RunCore, OS X/Win 7, internal PCI-e SHDC Reader Mini3: Mini10v. Black, 2G, Webcam, 640G HD, OS X 10.5.8/Win 7/Ubuntu [Hibernate w/NBI 0.8.3 RC4] Dropbox Referral |
(#9)
| Super Moderator Posts: 5,774 Join Date: Nov 2008 Location: New Hampshire | Do you need to leave this jump drive connected all the time? Or is it that you're using it for an additional purpose? You can set the protection of the folder with the Win7 install to read-only for all, but malware could easily get around that. Mini 9|2GB RAM|64GB RunCore|Intel 5300|Windows 8 |
(#10)
| Retired Mini user Posts: 1,577 Join Date: Oct 2008 | You could fill the flash drive up so there's no space for malware or a virus to add files. Use fsutil at a command prompt. fsutil file createfile <filename> <length> ...where length is in bytes. Just create a file big enough to fill the flash drive. |
(thanks mdd for my runcore!) and i have my win7 on a flash drive, but am kinda paranoid about virii sneaking in and dont wanna risk anything infecting it. does anyone know how to write protect it easily? i've searched online and the only things that come up are solutions that seem to only work on that particular machine (ie. if i change the registry on my desktop, i wont be able to write to my jump drive there, but if i stick it into my laptop, i can write there just fine). i dont wanna hafta regedit every machine i go to. any ideas?
