jds394 jds394 is offline
Default Replacement Power Adapter - 12-09-2008, 10:35 AM
I'm looking to buy a second Power Adapter to be able to leave in my office. Does anyone know where I can purchase one?
I'm in the UK so require one with a UK plug socket.
Josh
My Mini 9: Black, Windows 8 Beta, 2GB RAM, 32GB Runcore SSD , 32GB SDHC, Mobile Broadband
Quinten Quinten is offline
Default Re: Replacement Power Adapter - 12-09-2008, 11:41 AM
Dell would be too obvious?
I've seen several (genuine) Dell PSU's advertised on ebay too.
strider_mt2k's Avatar
Default Re: Replacement Power Adapter - 12-09-2008, 01:05 PM
Have you tried a Google search?
This seems to be a fairly elementary task.
Default Re: Replacement Power Adapter - 12-09-2008, 01:06 PM
I'd have thought it was faily elementary but I've looked and I can't find them on the website. The mini 9 is not listed under the models of laptop when searching for power adapters.
I can find a US one on the US site but nothing on the UK site
Josh
Default Re: Replacement Power Adapter - 12-09-2008, 01:57 PM
I see.
I can't really recommend a US one with a plug adapter on it. It's a bit kludgy for something to have to live with day in and day out.
Universal adapters are an option, but always pricier.
:idea:
Member "Zaden" has a thread devoted to Dell internal part numbers.
dell-mini-9-part-numbers-dell-internal-t734.html
I suppose you could PM Zaden for some advice of you don't get anywhere with the part numbers.
Ran Ran is offline
Default Re: Replacement Power Adapter - 12-09-2008, 08:22 PM
I bought a couple of these on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0285613336
That's US instead of UK, of course, but the cable that plus into the end is extremely common and the adapters are said to take input of voltages in a world use range -- you might already have some lying around, it's the same two prong one that lots of devices use.
You might be able to find UK specific ones as well.
It's very different from the standard dell one; very much a standard notebook adapter, but if you are just leaving one at work, who cares?
paneity paneity is offline
Default Re: Replacement Power Adapter - 12-24-2008, 07:53 AM
Don't get me started.
My UK Mobile-phone-style charger's central prong fell off in my bag. I called Dell to enquire about a replacement, under warranty and they said it was fair wear and tear, so no replacements. Hmmn.
I then got transferred to Sales who said yes they do sell replacement adaptors for Minis in the UK and I should look on the website. I said I'd already looked and hadn;t found, so asked them to stay on line whilst I found them. Sales then said they were US only. I went round this merry go round 2 or 3 times before throwing in the towel, and bought a couple off ebay. They are not mobile phone style, but they do the job, and are not as bulky as you might think.
Oh, and don't waste your time visiting obscure manufacturers websites trying to find the mobile phone style ones (as I did) unless you speak Korean, and are wanting to bulk order several thousand at a time.
Good luck
davico_rosello's Avatar
Default Re: Replacement Power Adapter - 12-25-2008, 09:23 AM
do you know that the mini power adaptor is "universal"? i mean, for example, i got a Aspire One too, and i can use both adapters in both machines
BUT, mini's adaptor is muuuuch smaller jeje
so, any 19V-1.58A power adapter should be fine
look here: http://www.laptopshop.co.uk/ac-adapters.htm
sory me no spiko english
AdAstra13 AdAstra13 is offline
Default Re: Replacement Power Adapter - 12-28-2008, 06:06 PM
I just bought two of these on eBay for about the price of one from Dell:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... %26fvi%3D1
The ebay seller lists these as "Brand New Dell Original", they are not OEM but build quality seems good and no problems so far (knock wood...).
Cheers,
--Joe
Dell Mini 9-Onyx-Windows XP-2GB RAM-8GB SSD-Bluetooth 2.1-1.3MP Webcam
Default Re: Replacement Power Adapter - 12-29-2008, 12:03 PM
Does it matter if the current rating is higher than 1.58A? Persumably the computer will draw what it requires to charge it?
Josh
« Diablotek?? External DVD | What external hard drive are you using? »
