davico_rosello's Avatar
Default Re: Replacement Power Adapter - 12-29-2008, 01:04 PM
Originally Posted by jds394
Originally Posted by davico_rosello
so, any 19V-1.58A power adapter should be fine
Does it matter if the current rating is higher than 1.58A? Persumably the computer will draw what it requires to charge it?
Josh
i think the current is request for the system, so the important thing to watch out is de voltage.
check this out:
http://www.laptopshop.co.uk/laptop-note ... -packs.htm
so, basicaly the amps help you to calculate the correct watts for the adapter
for the mini, 19Vx1.58A=30W, any 19V charger above 30W should be fine
sory me no spiko english
yorgle yorgle is offline
Default Re: Replacement Power Adapter - 12-29-2008, 04:53 PM
I just dug through my junk pile and found an old Compaq ps with the same connector as my mini and as luck would have it, it also outputs 19v at 3.16 amps, plenty of power for my mini. It's charging my battery right now. The point of my story is before you run out and buy another adapter, look around because you might already have one.
W99DEY W99DEY is offline
Default Re: Replacement Power Adapter - 01-08-2009, 04:14 PM
Does anyone know exactly what size the adapter tip is i.e. 5.5 outside 1.7 on the inside?
There are plenty of chargers out there @19v, the key is to get the right connector I guess.....
The ASUS Aspire 1200 adapter seems to fit the bill!
  (#14) Old
Default Re: Replacement Power Adapter - 01-13-2009, 08:33 AM
I have ordered an asus aspire one off ebay.
Should arrive in a couple of days...
I will keep you all posted............
  (#15) Old
Default Re: Replacement Power Adapter - 01-13-2009, 10:35 PM
5mm outside 1.5mm inside, measured with a tailor tape
  (#16) Old
eddiem5 eddiem5 is offline
Default Re: Replacement Power Adapter - 01-13-2009, 11:35 PM
I found an ordered this one from a ebay seller and it works great.. It is not 100% exactly like my Dell OEM but is very close and so far has worked quite well...
http://cgi.ebay.com/ws/eBayISAPI.dll...lenotsupported
-ed-
  (#17) Old
Default Re: Replacement Power Adapter - 01-16-2009, 11:27 AM
As in the UK I ordered "New AC Adapter Power Supply for Acer Aspire 1200 (G92)" fitted with a standard 3 pin plug.
This comes with the 5.5 outer 1.7 inner.
http://cgi.ebay.co.uk/New-AC-Adapter-Po ... 240%3A1318
Arrived next day! The plug fits in tightly with no movement. It is also rated at 19V.
I went for the OEM version, but there are cheaper on ebay.
  (#18) Old
vickoxy vickoxy is offline
vickoxy's Avatar
Default Re: Replacement Power Adapter - 01-18-2009, 05:59 AM
Hi,
i want to buy one dell mini 9 in UK, but i am concerned about Power adapter (i live in Austria). I have this one for my Acer Aspire One:
http://cgi.ebay.at/LADEGERAT-NETZTEIL-L ... 240%3A1318
Does anyone know if this one fits to dell mini 9?
Thanks
  (#19) Old
Default Re: Replacement Power Adapter - 01-18-2009, 07:42 AM
Originally Posted by vickoxy
Hi,
Thanks
my mini adapter works in my acer aspire one. is the same tip, it should work
  (#20) Old
vickoxy's Avatar
Default Re: Replacement Power Adapter - 01-18-2009, 07:54 AM
Thanks, davico_rosello. Well i ask it because i noticed that the same adapters types for dell mini have 20V and this one is 19V. But i really know nothing about these things, so...
« Diablotek?? External DVD | What external hard drive are you using? »
