crabtang crabtang is offline
Default simple & low cost alternative of external CD/DVD drive - 10-11-2009, 01:34 AM
You may need a external CD/DVD drive for re-installing OS.
There is a simple way can save you 50 bucks.
just use the trial version of ULTRAISO, write the windows installation cd image to a usb flash drive, then boot from the usb key to install windows.
I did not dry this on ubutun/linux installation. it should be ok.
BIN to ISO converter, ISO CD image editor and creator - Ultraiso Download Page
tchariya tchariya is offline
Default 10-11-2009, 04:15 AM
I read somewhere that places like Frys might be clearing out there external USB HDDVD players since the format is no logger being supported by the big manufacturers.
Might want to take a peak around for this. Post link back here for others that might be looking for cheap external DVD drives.
Mini 10v
Mikaboshi Mikaboshi is offline
Default 10-11-2009, 05:41 AM
you don't need an external cdr to install an os. I installed windows7 on my mini9 with just a usb flash drive.
Mine: Alpine White/Midnight Garden | 16GB SSD Hard Drive | 1GB Ram | Windows 7 | 1.3Pxl cam | Built in Bluetooth | 16GB SDHC Card
Cool 10-11-2009, 07:11 PM
This utility works great to install the setup files onto a USB..I used it when I upgraded my 160gb to a 500gb drive
you can get it here:
RapidShare: 1-CLICK Web hosting - Easy Filehosting
external dvd/cd
« Cases and Bags for the 11z? | Lap Desks? »
