m.weed m.weed is offline
Default external case for 16GB mini9 SSD - 09-15-2009, 06:18 PM
Hello,
i have the original 16GB SSD replaced with a 32GB SuperTalent SSD.
Now i hav a question about the "old" SSD.
Is it a externenal case available for the formfactor SSD ?
Where can i buy?
thank you and sorry for my horrible english
regards
marco
Default 09-15-2009, 06:28 PM
No such item is available - many have asked. I read that MyDigitalDiscount was looking into finding someone to build one, but I haven't seen it yet. I suggest that you just put the old SSD away for safe-keeping.
seniorusn seniorusn is offline
seniorusn's Avatar
Default adapter - 09-15-2009, 07:16 PM
Originally Posted by m.weed View Post
Hello,
Where can i buy?
regards
marco
There isn't a case, however there is an adapter at USBMA┬*(PCI express mini card to USB adapter) and if you check the compatibility - it will work with pata ssd's - the USBMA modual is $15.00 - check it out -
Obsidian Black Dell Mini 9 - 2gb ram, 32gb ssd, 1.3mb wc, bt, Windows XP Pro (Yeah!!!)
Default 09-15-2009, 07:40 PM
seniorsun, did your read the page you linked to?
Notice:
USBMA is USB passive adapter. Just only support wireless USB minicard. Can’t support PCIe minicard.
All this device does is allow use of USB MiniPCIe cards, such as wireless adapters, using an external USB port. The compatibility chart has X for the SSD entries, except for a product called MP2S which doesn't exist on their site.
Default 09-15-2009, 07:58 PM
Thanx for your fast answer.
So i will store the "old" SSD for safe-keeping.
best regards
marco
seniorusn's Avatar
Default 09-15-2009, 08:09 PM
I was reading that warning as pertaining to the USBMA which is a wireless device - however I was looking at the USBMA module - which can take the pata ssd to usb - at least that is the way I was looking at it........
Thanks for pointing that out though - there is also an $18.00 handling/shipping charge -
Default 09-15-2009, 08:50 PM
No, it doesn't do that. All it does is pass USB to a MiniPCIe card that uses the USB pins, as wireless cards do.
« Mbox 2 Mini Pro Tools LE 8 Works on OSX!! Mini 9 | Apple Mighty Mouse »
