Denis54 Denis54 is offline
Default Could I add a DVD drive this way? - 08-05-2009, 10:07 PM
I have an old DVD drive that I do not use. Could I use a USB to IDE converter cable to connect my DVD drive to my netbook?
Here is an exemple of the type of converter I have in mind http://www.newegg.com/Product/Product.a ... 6812156017
The newegg kit comes with a power adapter to power the drive
Retired Mini user
WolfKeeper's Avatar
Default 08-05-2009, 10:26 PM
Yes, absolutely. I used one to do an OSX install a few months ago.
Getting an iPad
Kilroy Kilroy is offline
Kilroy's Avatar
Default 08-06-2009, 04:57 AM
You could always buy an external case for the DVD drive. Whether it is a full sized desktop drive or a laptop sized drive, you can get cases that will turn it into a USB drive. I did that for a DVD burner out of my laptop when I replaced it with a Blue ray drive.
« Sleeve/Bag for Mini 10v with 6-Cell Battery | WiFi + Bluetooth Combo Mini PCI-Express Card »
