Default Noobie help request - 08-11-2010, 04:33 PM
Hi- I'd like to have a mini running OSX. As I understand it the easiest way to do that is to get a Mini 10v and set it up to run OSX. If this is true, are there any 10vs to be avoided (ie will the Slime ones work)? Also, can someone direct me to the easiest set of instructions to do this? I'd also be willing to buy a well functioning mini with OSX working. Thanks -Howard
Default 08-11-2010, 08:49 PM
I don't think the Slime 10v's are different in any meaningful way.
As for hackintosh info, you'll have to ask someone else.
Default 08-12-2010, 01:37 AM
I have the Slime 10v and had OS X running on it for about a week.
Everything worked fine, OS X just wasn't for me.
I followed mechdrew's guide (installation from any operating system)
Guides | OS X | mechdrew
Mini 10v/Slackware 13.37 RC π
« Installing W7 after OSX on GPT drive? | Need up-to-date guide to ADD Mac OS to Win 7 for dual boot using external HDD »
