I decided to replace one of the three OSs on my Mini 10v HD with WinXP but I've run into a partitioning problem. If this has been answered somewhere else I'm not finding it.
Okay, I booted into OSX and used Disk Utility to erase and reformat the second partition as FAT32 (100GB). The first partition is the EFI, the third one is OSX (180GB), and the last two are for Linux and its swap partition (about 30GB). So far so good.
When I reboot Chameleon shows me three choices: Windows FAT32, OSX, and Linux. I can boot either OSX or Linux with no problem. The Windows FAT32 won't boot of course because it's an empty partition.
Next I attached an external DVD drive and tried to install Windows XP, but when it gets to the screen that asks where I want to install the OS the only choice I have is my 30GB Linux partition!
What do I need to do to the 100GB second partition so that the Win XP install will find it?
