Default 08-05-2010, 10:12 PM
Sounds like it might be choking on weirdness due to the hybrid MBR/GPT partitioning used on hackintoshes. I believe Jolicloud also uses an older version of GRUB, it might not like hybrid partitioning.
A tool like "gptsync" might be able to help (gptsync makes the MBR partition table match the GPT table).
Default 08-06-2010, 03:55 PM
For (almosts) all thing GRUB related it's good to have this page bookmarked.
Default 08-06-2010, 06:46 PM
Tried gptsync from both MacOSX and from Ubuntu and it does sync the MBR and GPT. But I still got the same error.
  (#14) Old
Default 08-09-2010, 04:45 PM
Originally Posted by eatabagel View Post
...And then I did a ls /dev/sd* and it showed that the only partitions listed in /dev were /dev/sda1 and /dev/sda.
I spent a few hours trying to dual-boot SL and JoliCloud, including work at the command line changing which was the boot partition. My conclusion: you're on to something important. I suspect that unless JoliCloud is the first partition, you're going to be hosed.
« Yikes ! ! ! Success ! ! ! OSX and XP ! ! ! | Installing W7 after OSX on GPT drive? »
