R3Y3S R3Y3S is offline
Default Help dual boot - 09-21-2009, 02:53 PM
Hi guys,
I have successfully intalled os x 10.5.8 on my dell mini 10 using a method netbootmaker and DellEFI. I want to install de dual boot with windows 7. Can anyone point me what i need to do. I don't want to lose my osx installation.
jakrabit jakrabit is offline
Default 09-23-2009, 06:57 PM
when you setup your OS 10.5.8, did you create partitions?
you need 3 partitions...
if you didn't have 3 partitions, you might be better off starting over using the info from http://www.mydellmini.com/forum/mac-...ndows-7-a.html
« clone triple boot mini | Planning a rebuild - Doing a triple boot - Need some pointers. »
