Dual Booting Guides Guides for setting up your Dell Mini to run 2 operating systems or more.
Comment
LinkBack Tutorial Tools Display Modes
Creating the ULTIMATE multi-boot recovery USB Drive
Published by Side.Step.Society
01-08-2011
Lightbulb Creating the ULTIMATE multi-boot recovery USB Drive
Greetings all,
I've got an easy breezy tip for you multi-boot-ers.
Multi-booting on our notebooks can be kind of a fight sometimes. And carrying around different USB drives for different operating systems can become quite cumbersome when you're triple booting and on the go. So, I've come across a method to fit all your favourite OS installers on one USB drive.
What you should probably get/have:
-One USB stick, preferably 16GB in size, although, depending on your OS choices/requirements, 8GB may work as well.
-Probably going to need a computer, in this guide I'll be using OS X and Windows on my 10v.
-NBI 0.8.5pre. I imagine earlier versions may work as well, however, this is what I used and it works quite well. If I had to guess, I would say any NBI that supports Windows dual boot will work.
- Windows USB/DVD Download Tool
- A DMG of the OS X Install DVD and an ISO of the Windows 7 installer. (Not sure if earlier versions of Windows will work or not.) If you haven't made an ISO of your Windows 7 disc, I suggest a program called "ISODisk". It's the only one that worked for me.
-One stainless steel fork. (You'll understand why later.)
Crack your knuckles and let's begin!
Part A - Formatting the Drive:
In this first step, we'll simply be formatting the drive to prepare it for multi-booting.
1. Boot to OS X, insert your USB drive and open up "Disk Utility".
2. Click on the USB drive and go to the "Partition" tab.
3. This step will vary depending on your needs and the size of your USB drive. If you're triple booting, create three partitions. In my case, I chose 3 partitions:
Partition 1 - Windows 7 Ultimate installer - Roughly 4GB
Partition 2 - Mac OS X Snow Leopard installer - Roughly 9GB
Partition 3 - Storage space - Roughly 4GB
You'll need to resize these partitions to fit each desired installer, of course. I should also note that the third partition (as of now) is only visible in OS X.
4. Click the "Options" button and set it to use Master Boot Record.
5. Click "Apply" and your flash drive will be ready for the next step.
Part B - Copying the Installers:
Now we'll be restoring the installers to the USB drive itself.
1. We're going to start with the Windows installer. This will have to be done in Windows.
2. Install and run the Windows USB/DVD Download Tool.
3. Locate your Windows 7 ISO and plug it into the program, then choose your USB drive. Since Windows can only see the first partition, it will copy the ISO to that partition and it'll be completely bootable. It's quite straight forward.
One down, one to go.
1. Now we'll do the OS X Installer. This is basically the same as creating a drive for your hackintosh with NBM/NBI. The only difference is choosing the correct partition.
2. Open up Disk Utility and restore your OS X DMG to the second partition on your USB stick. Click "Restore".
3. Prepare your fork.
4. Go into the kitchen and stab some food with your fork. Eat said food.
5. Once you're done eating, check on the restore process and see if it's done. It'll take a little while on the mini 10v.
6. When it's done, run NBI 0.8.5pre, make sure you select the "Mac OS X Install DVD" and not your "Macintosh HD".
VOILLA!
That's it! Your multi-boot USB drive is ready to use! No more fighting with multiple USB drives. You can boot to whichever installer you please. And although I have yet to try it, I imagine Linux would go on the third partition quite easily as well.
So now, if you haven't already set up dual booting, prepare your fork for battle, go attack some food, and enjoy the simplicity of one USB drive for all of your operating systems!
-Chris
Tutorial Tools
Featured Tutorials
  #1
Old 01-08-2011, 07:36 PM
Oscar's Avatar
Default
I like this tip. Thanks for posting.
Cheers.
__________________
Please use my Dropbox Invite link: http://db.tt/4z2wwup
Old 01-08-2011, 10:55 PM
Side.Step.Society's Avatar
Send a message via MSN to Side.Step.Society
Default
Glad to hear it! Thanks!
Old 01-20-2011, 01:29 PM
Default
Side.Step.Society, thanks for the tip !!!! do you have any suggestions/tips for adding Linux as the 3rd O/S on the 3rd partition ? Should that be created in Linux like windows & osx ?
Old 01-20-2011, 01:41 PM
Default
My thoughts are it would be best to do it through Linux via Startup Disk Creator if possible. You could give that a try.
Old 01-20-2011, 01:45 PM
Default
3S, thanks. I'll keep you posted
Old 01-20-2011, 02:01 PM
Default
Great! Thanks for testing for me! :P
Old 05-19-2011, 09:23 PM
Default
thanks for this useful information.
was thinking about how to create a multiboot with mac os.
i can add something for you:
USB Mutliboot creators
they're loads of USB creators for Win and Linux which create all possible boot iso's on one stick.
will try it later
UPDATE:
hmm, didn't work properly... get error message when booting. seems like NBI didn't create the right bootloader on it. any ideas what i did wrong? will try with another multiboot creator.
__________________
Dell Mini 10v - 1011 - (triple) boot
Old 01-24-2012, 11:10 AM
Timelord83's Avatar
Default
i have an issue all seems to go while till i try to install the macOSX from the usb key then it just randomly reboots mid install and fails. i know the mini 1012 is an unsupported model for osx 1.6.3 but i did have it running good until i accidently updated to 10.6.8 and screwed myself. but i can't seem to find the iso for the CD i booted with for that install. and as far as i can tell the NetbookInstaller 0.8.5 pre reboots mid install. the netbookBootMaker doesn't even allow the USB stick to be bootable throws some error and you have to restart the machine. my DVD is known good and i am doing the USB dongle restore on a Mac Laptop so i have no idea whats going.
Old 03-07-2012, 06:59 AM
Default hxxp://liveusb.info/dotclear/ LiveUSB MultiBoot
MultiSystem MultiBoot LiveUSB Best App Ever, runs on linux only
Comment
dual boot, recovery, usb
« Easiest Windows 7/Snow Leopard Dual Boot, with Chameleon | - »
Tutorial Tools
