kimo96745 kimo96745 is offline
Default Radio Reference does not work - 08-31-2011, 05:46 AM
Aloha ! I have a Dell Streak 5 which I really like except for one thing, Scanner Radio will not connect to any channel, same for Radio Reference. Maybe one time in 20 when I try to connect to Scanner Radio it WILL work on the first channel I try but when I then go and try another channel it just stays at
"connecting..." and never goes to "streaming".
I tried all the usual stuff, uninstall and then reinstalled etc. Skype and
TuneInRadio work just fine.
Some sort of conflict but I have no idea what to try. Any Ideas ?
Australian Australian is offline
Australian's Avatar
Red face Radio Reference Doesn't Work - 08-31-2011, 09:44 PM
I presume Radio Reference is an app?
I know there are a number of apps for scanner radios.
There are many badly designed apps. that do not work well, e.g."ABC 24 Hours" - a private app for the ABC TV News channel in Australia.
The video always freezes whilst the audio goes on streaming.
One of the History Eraser apps no longer works after an update.
So, nothing wrong with your device, - seems the apps are not well designed, or your 3G just isn't up to the job.
« Streak getting formatted on restart | samsung galaxy note »
