mattnuttall mattnuttall is offline
Default Please Help!?!? - 06-10-2011, 09:18 PM
After fiddling with the engineers settings i came across the code *#*#303#*#* which activated the "MMI Tool" this however has now left an "MMI Tool" icon on my application list and it is very annoying and also activates USB Debugging when I connect to my dock/pc. I was wondering if anyone could tell me how to get rid of it or disable it preferably without having to wipe. I also cannot access emlist i recieve the message "Need Correct PASSPORT in SD card, Please check it!".
Im running Android 2.2 which is rooted. Any help would be greatly appreciated as im completely stumped on how to get rid of this and get my emlist working again.
Cheers and thanks for any help in advance
Strephon Alkhalikoi Strephon Alkhalikoi is offline
Strephon Alkhalikoi's Avatar
Default 06-20-2011, 06:07 PM
Try *#*#307#*#* and see if that works.
Omkar Tavsalkar Omkar Tavsalkar is offline
Default 08-18-2011, 01:05 PM
Hi there,
I have downloaded the Dell PC suit 2.1 for Dell Streak with Android 2.2.2. but when im connecting my Streak to PC the suit doesnot works. Please suggest me the best way to connect my Streak to PC as I have to take backup of Contacts n calender entry on my PC. And my other query is how shud i sync my calender entries from SD card to actual calender of dell as i have restored those entries from my previous phone's backup.
popatim popatim is offline
Default 09-07-2011, 01:15 AM
PC suite 2.1 is for android 2.1
You need mobile sync 2.2 for android 2.2
app icon, emlist, hiding icon, mmi tool, removing system app
« samsung galaxy note | 11/09/11 Notification Malware »
