Question Issue: Wi-Fi & Bluetooth not starting - 03-01-2011, 06:43 AM
Hey all,
Since I came back from a trip by plane and had airplane mode enabled, my Bluetooth and most importantly my Wi-Fi will not start its services anymore. Whenever I try to enable Wi-Fi, it just says "Error" and if I try to enable Bluetooth, it continuously says "Turning on..." and will only stop if I reboot the device.
I have tried redisabling airplane mode multiple times, taking out the battery multiple times and did a factory reset. None of this worked. I am now thinking about re-installing Froyo, But I don't know how to, as I can't find an official ROM online (I can't update using my Streak since it has no Wi-Fi...)
Can anyone help?
Arcturus
Default 03-10-2011, 12:04 AM
You dont need wifi to update, 3G will work just beware of the data rate plan you are on if its not unlimited.
airplane mode, bluetooth, error, wi-fi, wifi
« Wallpapers | Streak5 with latest droid os »
