superutp superutp is offline
Default Chargin the Streaks Battery - 10-24-2010, 07:45 PM
kind of a dumb Q but even then..
I am getting my streak tomo...just wanted to know about for how long the battery should be charged...should it be overnight(like 8-9 hours) or should I make sure its only kept plugged till it completes charging...
i once had a nokia 5700, and screwed its battery up because of over charging etc...
is there anything specific that I should be aware of??
PLaCiD PLaCiD is offline
Default 10-25-2010, 08:33 AM
I usually put mine on to charge for about 40 mins every day or 2.
I think overcharging may indeed damage the battery.
Is there a light at the end of the tunnel ...
Or is it just the front of an approaching train!!!
Dunhamzzz's Avatar
Default 10-25-2010, 10:59 AM
I keep mine plugged in during the day while I'm at work (HDMI dock!), have had no apparent problems with 'over-charging'
bigrob bigrob is offline
Default 10-25-2010, 12:15 PM
I plug mine in over night and use it as my wake-up alarm.
No probs.
I also use the car charger when going any distance in the car.
crowcrow crowcrow is offline
crowcrow's Avatar
Wink 10-25-2010, 12:38 PM
Yeah, these li-po batteries should be fine with anytime charging, don't need to wait until totally dead etc. - just charge as and when needed. And can leave plugged in as long as you need. (I do mine overnight)
Soldier1969 Soldier1969 is offline
Default 10-28-2010, 01:01 AM
Use a battery saving app from app store their free. first day everything was running I got about 9 hours of juice after a overnight charge. Today I got about 14 hours with the battery saver app.
PC Gamer,Electrician,Hadyman,Artist,American Soldier Dell Streak owner.
« Front-Facing Camera Support in 2.2 v1? | Official Froyo »
