Send a message via AIM to Streaker503
Default Please help...I'm stuck at updating my Streak... - 09-02-2010, 08:56 PM
11-Once you're in the right place, type fastboot.exe -i 0x413c flash recovery c:\recovery.stock.img and hit Enter.
12-When you see "Download RECOVERY Done!" on the Streak, remove the back cover and pull out the battery.
13-Replace the battery and back cover. Hold the volume up and down buttons down while pressing the power button and choose option 2 from the menu that will appear.
14-Relax for a few minutes and wait for the Streak to reboot. You'll see the O2 splash screen because—drum roll—you've got the stock O2 ROM (build 4399) running on your Streak.
So I have managed to get to step 13 and then I get boned... Once I reboot and choose option 2 "software upgrade via Update.pkg on SD card"
When I select option 2 nothing happens and I get this prompt: "to perform an emergency software recovery, you will need to insert a microsd card containing an update file. (/sdcard/update.pkg)
Arg. Please help. I have the update.pkg file on my sd card. I just dragged and dropped it into the sd card. Do I have it in the wrong place?
Default 09-03-2010, 03:15 AM
nevermind. I dont know what i did but i managed to get 2.1 running. it was a bizarre method. It made my 2 day old streak 10 times better.
crowcrow's Avatar
Default 09-03-2010, 11:01 AM
Which update did you use out of interest?
Default 09-03-2010, 04:49 PM
I believe it was the original leak. It's working great. No hiccups. So much better. Why Dell didn't include this at launch is beyond me.
« Update is online! Go do it folks | iPad seems to have more problems than the Streak »
