Dell Streak Support Forum for Dell Streak owners to get help and support for their Streak.
Default Help battery icon is a ? And keeps powering down - 02-08-2012, 04:41 PM
Hi my dell streak 5 running I think 2.2 maybe .1 anyways ive replace my battery and screen on my streak and still get a ? In my battery meter and am at my wits end tring to find some1 else who has had this problem. I hope some one knows y/how to get read of it. Sometimes it just wont power up either
Default 02-09-2012, 11:42 PM
Try a factory reset but uncheck the 'Automatic Restore' (restores all your apps) in Privacy Settings first.
If it works again, add your apps back in 1 at a time and see if its one of them thats causing the problem.
« Battery 100% then 0% | AT&T Streak 2.2 unable to import contacts from SIM card »
