Default OSX Snow Leopard On Mini 9 - No Wifi or Sound - 07-17-2011, 11:18 AM
Hi Guys
Hopefully you can help me - Im just starting out on this OSX thing!
Ive installed OSX using this guide : dailyblogged.com/1553/how-to-install-snow-leopard-on-a-dell-mini-9 and it all seems to work well apart from a lack on Network (both wifi and wired) and a lack of audio.
How do I get these working? It doesnt seem to be as straightforward as installing a driver like on Windows.
Many thanks in advance for your help.
Scooby.
Default 07-17-2011, 01:36 PM
Welcome to My Dell Mini.
That is an old guide and it is lacking one very important instruction.
It says to reboot after OS X has completed installing. This is incorrect.
Immediately after OS X has finished installing on your mini, when it gives you the reboot countdown, you should go to the menu bar at the top of the screen and select Utilities and run NetBookInstaller with the default selections that are already checked off. This loads the boot loader, and all the kexts required to allow the track pad, video, and wifi to work properly.
NBI should be in your mini's Applications folder as well, and you can run it from within OS X as well. This should fix your issues.
Functioning Hibernation
Default 12-08-2011, 01:38 PM
What is the most up to date guide? I can't figure it out.\
Thanks!
« Help - OS X 10.6.8 | Newbie moron question about direct install »
