CodF4ther CodF4ther is offline
Default Sound issues due to broken wires - 02-12-2011, 06:57 PM
Now that our Mini9s are getting on in years, I thought I would alert everyone to an issue I had. Sound had stopped working on my Mini9 and I was blaming it on a bad upgrade. After wiping, and fully reinstalling 10.6.3 I still couldn't get it to work. I tried Linux, still no luck. I decided to take the machine apart and notice that the 4 speaker wires running through the hinge to the screen had all broken off. I soldered in some small wires to bridge the gap (the wires are not long enough to simply re-join) and sealed the with some heat shrink. Sounds now working perfectly again. Anyways, if you're having sound issues and can't get anything else to work this is probably worth checking.
Default 02-12-2011, 10:54 PM
Thanks for the info... I hope I never need it
« Mac OSX update mistake! | grey screen after booting »
