redmini redmini is offline
Default GMA 950 problems - 07-27-2010, 12:26 AM
hi guys, I know its not a dell mini but got problems with 950 gma card on my Vaio VGN-N38E. The reason I posted on here was because I have had excellent advice off here before, on other forums you just get links to other threads and they say "read that". I have done lots of research myself but am getting very confused whether to use kexts, strings or DSDT or all three
My question is how do I get my gma 950 running smoothly and at full resolution. When I use for example expose its very jerky were as on my dell mini 9 it isn't I think I need to enable quartz extreme but I just don't know how.
this is what my system profiler reads
Intel GMA 950:
Chipset Model: GMA 950
Type: GPU
Bus: Built-In
VRAM (Total): 64 MB of Shared System Memory
Vendor: Intel (0x8086)
Device ID: 0x27a2
Revision ID: 0x0003
Kernel Extension Info: No Kext Loaded
Resolution: 1024 x 768
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
i'm sorry I posted my question here just wanted to get the best advice possible
thanks in advance Jake
« dell mini tablet | Kernel Panic on start-up »
