maddog maddog is offline
maddog's Avatar
Default 04-18-2010, 06:09 PM
Originally Posted by papars View Post
The procedure works but I must make some comments.
-In the above sudo commands there must be a space between cp and -R.
-Sudo will fail if the password is empty. Use passwd to add a password, run the commands and use again passwd to remove the password.
Thanks for your comments.
I don't know how I missed the space in the cp command. It is fixed now.
As for not having a password, I was not aware of that.
Could you check if the HDA extension is in the /System/Library/Extensions/ folder?
Dell Mini 9 (Vostro) 2GB Ram - 32 GB RunRev SSD - A05 - OS X.6.5- NBI 20100616212351
movlas movlas is offline
Default Easiest Mic Fix for Mini 9 & 10.6.3 - 05-01-2010, 10:07 PM
Originally Posted by maddog View Post
I just improved a bit the method.
One needs to be administrator to do this.
Many steps will need authentication.
If your sound is not working then do the following:
I. Run NBI RC1 and choose
  1. install bootloader
  2. install ... extensions
  3. regenerate a system specific DSDT ...
The other options are up to you.
When done,
II. Run "UpdateExtra" in the "/Extra/" folder.
III. Download the files I have on my first message to this thread.
IV. Restart.
V. Replace the DSDT in "/Extra/" by the dsdt you downloaded from here.
VI. Copy the extension AppleHDA.kext to the folder "/System/Library/Extensions/" via the Finder
VII. Run diskutility to fix permission. <----Important
VIII. Run the following command in terminal:
(copy exactly as I have here, make sure that the folder name is right for the Mini 9)
sudo cp -R /System/Library/Extensions/AppleHDA.kext /Extra/A90Ext/ <--- for Vostro
sudo cp -R /System/Library/Extensions/AppleHDA.kext /Extra/Mini9Ext/<--- for Mini 9
Note: my Vostro has A90Ext, on a Dell Mini 9 the name is (apparently) Mini9
IX. Run "UpdateExtra" in the /Extra/ folder.
X. Restart and you are done. Sound should be working.
HINTS: to go to the /Extra/ folder (invisible) type shift-cmd-g or select "Go to Folder" from the "Go" menu in the Finder menu bar.
Need help ask!
This is by far the easiest method of all posts I have seen.
It worked on the first try.
Thanks for the good work.
One question:
Is there no way to incorporate the files into the NBI so that it updates the kext without the terminal process?
Mini 9, 1.6GHz, 2 GB RAM, 32 GB AMP SSD, OS X 10.6.3, [A04 BIOS to fix the non-Dell battery glitch] (all else Mac; Lisa 2/10 thru iMac 21.5" 3.33 x 8 GB)
« Removing Leopard from Dell Mini 9 to install SL | Battery question... »
