| Member Posts: 71 Join Date: Jul 2009 | By default, Netbook Installer does not provide microphone support in current versions. Netbook Installer + Dell Mini 9 Audio with Microphone without VoodooHDA (Snow 10.6.2) is the best functional mini 9 for 10.6.2. All audio will work after the above. |
| Junior Member Posts: 6 Join Date: Mar 2010 | That's the type of tutorial I followed, I read the replies and saw one that said he couldn't boot his netbook any more. ---------- Post added at 04:07 PM ---------- Previous post was at 02:37 PM ---------- I got it working with this website tutorial: Dell Mini 9 on Mac OS X 10.6.2 fix for broken sound and microphone | Below Belief |
(#4)
| Junior Member Posts: 16 Join Date: May 2009 | install normally, then simply update the kexts in the /extra / dell mini 9 extensions folder as per Eligos's post I am reposting here (doesn't want to link nicely for some reason): Originally Posted by Eligos Works like a charm! Audio is near perfect (just a little audio glitch barely perceptible every 5 sec) and it resumes after sleep. iChat now works really well using the built-in mic. • Speakers work 100% • Earplug jack works 100% • Mic works 100% Note: I removed the one in S/L/Extensions to have no conflicts. Files : http://www.mydellmini.com/forum/atta...268_3.kext.zip http://www.mydellmini.com/forum/atta...amily.kext.zip This is awesome! Repost from posts below to make it simpler. ;-) Originally Posted by deadlyvirus(modified) 1. Go in Finder to the Go menu, and select "Go To Folder" 2. Paste this /Extra/Mini9Ext/ 3. Paste the 2 kexts (see links) into that folder. You will need to input your password. 4. Go to /Extra and run UpdateExtra application. 5. Reboot and you're done. |
(#5)
| Junior Member Posts: 10 Join Date: Dec 2009 | I resolved my mic problem like this way: Dell Mini 9 Audio with Microphone without VoodooHDA (Snow 10.6.2) |
(#6)
| Junior Member Posts: 7 Join Date: Jul 2010 | Quote:
