fruitbat04 fruitbat04 is offline
Default Sleep with Bluetooth when on battery - 02-06-2010, 01:53 AM
OK after a bit of testing including doing a completely clean install using netbookmaker final, can anyone else confirm the following?
1) Install
2) Update to 10.6.2
3) Fix the microphone using the kext fix in this forum
If you sleep the macbook while on AC power, everything is fine on wake.
If you sleep the macbook on battery, everything is ok, apart from bluetooth which is shown as not available until you reboot.
Any fix for this?
jrabbit jrabbit is offline
Default 02-10-2010, 11:07 PM
Are you using Dell's Bluetooth chip with your Mini 9 or a USB one? I'm still trying to get pairing to work with mine.
Mini 9 OS X 10.6.2 A05 32GB SuperTalent
« OSX 10.6 > 10.6.2 question (noob) | Password Problem »
