Default No sound with a clean Leopard install using NBI 0.8.3 release - 01-11-2010, 06:02 PM
I just did a CLEAN install of Leopard and the sound drivers do not appear to be working at all. I searched and read many threads on different issues involving the audio in the Mini 9, but I could not find this exact problem. Using the 0.8.3 alpha release NBI build, I did not get anything listed in the Sound System Preference. I went back to the 0.8.3 RC4 NBI and was able to get audio working. I then reran the 0.8.3 release and it seems to be working fine. It appears the release installer is not working correctly.
panzercannon01's Avatar
Default 01-12-2010, 12:20 PM
Use the file that I just attached. Just unzip it, run, and reboot. you should be fine.
P.S. have you also had any keyboard issues? the on-board keyboard not working in OS X?
Default 01-12-2010, 02:09 PM
I also just did a fresh install of 10.5, then combo update to 10.5.8, and no sound drivers. I used Meklort's latest 0.8.3 netbookmaker, and bootmaker programs. Will run this tonight once I get home. And i'll let yall know if it worked.
No keyboard problems from the built-in keyboard. But Bluetooth was acting a little funny, and forgetting I had my apple wireless keyboard paired.
I am pretty annoyed since I specifically downgraded to 10.5.8 because sound was working in 10.5.8 before, but broke when I went to 10.6. I tried doing a fresh install of 10.6 after a week of me messing with sound drivers, with no success. I tried 10.6, and then a 10.6.2 combo update, which didn't help. So i'm back in 10.5.8, and still no sound.
Default 01-12-2010, 04:35 PM
did you try installing the file I attached above?
~You forgot to put the toaster on the ledge.
Default 01-12-2010, 05:42 PM
I am once i get home; at work now and no access to my dell.
EDIT
The file works! I have sound, and mic again! YAY!!! Thanks m8!
Default 01-13-2010, 05:22 AM
Can you tell me more about this file?
My current audio situation is what results from following a guide that I wrote a couple months back:
DellMini9 Runcore SSD/10.6.1/NI 083 RC3 (Full Sound, Sleep, Reliable Restart!)
Could I run your file and get static free sound and a working mic, both which work after sleep?
Thanks.
DM9 | 64GB Runcore SSD | 2GB RAM | BIOS A03 (USB LEGACY OFF, USB WAKE OFF, BT OFF)
OSX 10.6.4
Smile 01-16-2010, 03:06 AM
Thanks.
It is a file I had found on the internet when I too was having audio issues. The sound works perfectly for me with it. (dunno bout mic cause I never use it), no pops or anything. I only used it back with 10.5, 10.6 is what I am running now, and I've yet for a need for this file in 10.6 But then again I never use the mic, so....YMMV
P.S. use the latest revision of NBI, reboot, and if sound still does not work, use this file and reboot.
---------- Post added at 08:06 PM ---------- Previous post was at 07:59 PM ----------
EDIT
no problem!
Default 12-29-2010, 09:44 PM
THANKS!!! The ALC268 Installer file painlessly fixed my sound.
Eventually I worked out that the System > Sound Output had disappeared after the upgrade to 10.5.8. Yes I know it took me a while to fix it :-)
Cheers
Paul
Default 01-04-2011, 06:58 PM
Wow, this thread recovered my sound too, it just won't die! THanks!
clean, install, leopard, nbi 0.8.3 release
« 22" TFT an Mini 9 A04 10.6.4 | Reverting Back to XP....how? »
