(#21)
(#22)
(#23)
(#24)
| Senior Member Posts: 154 Join Date: Oct 2009 Location: Pittsburgh, PA | Quote:
Yea the audio works great, just no mic using ichat or rosetta stone. I pulled the AppleHDA from the /sys/lib/backupext the name is highlighted in yellow for some reason though. The version i have is 1.6.8a3, anyone able to post the stock AppleHDA for me? Apple TV | 160GB | CrystalHD iPhone 4 Powermac G5 Tower | 2x 2.0GHZ | 8GB Ram | 160+250 GB HDD | OS X 10.5.8 Leopard | 24" Acer | |
(#25)
| Member Posts: 52 Join Date: Apr 2009 | |
(#26)
| Senior Member Posts: 154 Join Date: Oct 2009 Location: Pittsburgh, PA | Quote: I patched it trying to get audio working in this thread: Sound and mic working with AppleHDA that might also be the problem. Apple TV | 160GB | CrystalHD iPhone 4 Powermac G5 Tower | 2x 2.0GHZ | 8GB Ram | 160+250 GB HDD | OS X 10.5.8 Leopard | 24" Acer | |
(#27)
| Member Posts: 52 Join Date: Apr 2009 | Quote:
IOAudioFamily.kext | |
(#28)
| Senior Member Posts: 154 Join Date: Oct 2009 Location: Pittsburgh, PA | thanks, after swapping those two files still no mic, audio works great, headphones work, just no mic. what is the mic listed as on your device? mine shows internal microphone / built-in mic audio still works and get info shows the correct version number for applehda Maybe I just need to format and reinstall Apple TV | 160GB | CrystalHD iPhone 4 Powermac G5 Tower | 2x 2.0GHZ | 8GB Ram | 160+250 GB HDD | OS X 10.5.8 Leopard | 24" Acer |
(#29)
(#30)
Device ID: 0x102802B2 Audio ID: 12 Available Devices: Speaker: Connection: Internal Headphone: Connection: 1/8-Inch Jack Line In: Connection: 1/8-Inch Jack Internal Microphone: Connection: Internal If yours does too, then it really should work. | |
| Tags |
| audio microphone snow |
