twm1010 twm1010 is offline
Default 10.5.8 combo update need a little help - 12-10-2009, 07:08 PM
Using MechDrew's guide on my Vostro A90 (A04 BIOS). 8GB SSD.
I was able to get OSX 10.5.2 installed from a retail DVD imaged to an external hard drive. At this point, everything worked. Then I used monolingual to remove enough junk to free up space for the 10.5.8 combo update. The update process ran fine, however I had to use the tip at the end to change the boot plist from mach_kernel.10.5.6 to mach_kernel to get into safe mode. Once there NetBook installer crashes when I hit go, no matter what boxes are checked.
Any help is appreciated!
---------- Post added at 02:08 PM ---------- Previous post was at 01:31 PM ----------
thanks for the move, didn't see the OSX section at first.
« OSX 10.5.6 on Mini9 | 8G A90 space problems trying to update to 10.5.6 »
