Starby Starby is offline
Default Mini 9 EFI loader problem - 12-06-2009, 01:47 AM
So I followed this tutorial which is fantastic. I'm fairly computer literate but I'm a mac user at heart so I get a fairly muddled up with drivers and things PC users are used to.How to Install Mac OS X: DellEFI Method My problem enlies that I have 10.5.2 running on my mini, I do the EFI and then attempt the - or -x option and get nothing, I've tried doing the 10.5.7 update first and have had the same problem, I have to use the bootloader to get into the os and after the gray apple load screen pops up I get a blue screen and it just hangs there, forever.
Basically, after attempting the EFI I always get this blue screen freeze of death and I can't even tell if the EFI did it's job for drivers and such (I'm assuming it didn't because it wont boot natively) Does anyone have any recommendations? I've tried about 9 times and the 3-4 hour hard drive copy periods are starting to get to me.
Default 12-06-2009, 02:10 AM
I would suggest getting a copy of Leo 10.5.6 Retail and use the NBI/NBM instead of the DellEFI method, as it is obsolete and no longer supported.
Functioning Hibernation
« Installing from and to the same HD? | grey restart screen on boot up »
