| Member Posts: 49 Join Date: May 2009 | I upgraded from NBI 8.3(RC3) to (RC4) on a Mini9 using the usual process: 1. restarted into Safe mode 2. ran NBI 8.3(RC4) 3. restarted into Normal mode On restart, the screen resolution is stuck at 800x600. Restarting into Safe mode gives the correct resolution. Right now the only way I can get normal mode to work is to delete the 'dsdt.aml' file in /Extras and restart. If I regenerate the custom 'dsdt.aml' the resolution issue comes back. Is the 'dsdt.aml' file required? any negatives by not having one? Anyone else seen this or have a solution? |
| Member Posts: 49 Join Date: May 2009 | Thanks underwhelmed using RC3 worked! |
| Tags |
| 10.5.8, nbi, resolution |
