| Junior Member Posts: 7 Join Date: Oct 2009 | I had Ubuntu installed on my Dell mini 9 - wireless and sound were working great. I upgraded to 2 gigs of ram and also installed a 32GB Super Talent SSD yesterday. Along with this upgrade, I created a Snow Leopard USB stick with a retail Snow Leopard DVD and used NetbookMaker to make it bootable, etc. I used the Mechdrew guide -> http://osx.mechdrew.com/guides/nbi1.shtml for this. After the installation, everything worked fine except for the wireless part. My wireless card was not even being identified. I booted into single user mode and did the NetbookInstall thing too, but that didn't help with the wireless, and in fact, I lost my sound too. I ended up erasing the partition and reinstalled Snow Leopard from the USB drive. I still have the same issue of no wireless access ![]() I would really appreciate any help resolving this issue. Also, my mini does not seem to resume from sleep mode. Is there a known fix for this issue? ---------- Post added at 12:45 PM ---------- Previous post was at 12:43 PM ---------- I fixed the sleep/wake issue by disabling "USB legacy support" and "USB wake" - part of the problem solved. If only I can get my wireless to work, I would have the perfect portable device ![]() |
(#4)
(#5)
| Senior Member Posts: 122 Join Date: Aug 2009 | Don't know if this will help or is part of your problem, but, I could not get connected to Wi-Fi on my MBP after the Snow Leopard upgrade. I deleted the files listed in the following URL and that fixed my Wi-Fi issues. Major Airport Problem in Snow Leopard [problem solved] - Mac Forums BIOS A05 | USB Legacy: ON | USB Wake: OFF | Bluetooth: OFF | NBI .8.4 RC1.1 (20100616212351) Sleep: Working | Speakers: Working | Headphone Jack: Working |
(#6)
| Junior Member Posts: 7 Join Date: Oct 2009 | Ok, I just figured out that I have an Atheros ar5bxb63 card in my mini 9. After extensive searching, it appears that there is one 3rd party company offering drivers for this card, but it costs another $15. Do you guys think it is worth buying the driver? Or, should I just replace the wireless card? Which card do you folks suggest - best bang for the buck... |
(#7)
(#8)
| Senior Member Posts: 122 Join Date: Aug 2009 | Yeah, it appears that installing Snow Leopard with wi-fi off will cause you to not be able to reenable wi-fi. That was the problem with my MBP and was able to resolve by following the instructions in the following link. Major Airport Problem in Snow Leopard [problem solved] - Mac Forums I'm guessing on a Hackintosh, these steps should work as well, so, don't have to go in and reinstall a different OS before reinstalling SL. BIOS A05 | USB Legacy: ON | USB Wake: OFF | Bluetooth: OFF | NBI .8.4 RC1.1 (20100616212351) Sleep: Working | Speakers: Working | Headphone Jack: Working |
(#9)
| Junior Member Posts: 7 Join Date: Oct 2009 | Quote:
I have linux installed on my 8GB SSD and wifi is activated in linux. I swapped the SSD aand confirmed that my wireless card is on and active. But yet, it doesn't work in SL. | |
(#10)
