ebina1 ebina1 is offline
Default 10-03-2009, 05:10 PM
This same problem has been driving me nuts. I got the Can't Find mach_kernel.10.5.6 error on two separate installs using .8.2 final. Since I want to install leopard and not snow leopard, should I try the .8.3 testing release or is there and older .8.1 release I should use?
I too am using an older (I think 10.5.4) retail install DVD.
tchariya tchariya is offline
Default 10-03-2009, 06:22 PM
This happened to me on my 10v after some upgrade.
So what I did was this:
1) booted Mini...and when you get to the grey screen, hit escape
2) type mach_kernel, which will appear at the left bottom corner like when you boot -x for single user mode.
3) your mini should boot up all the way
4) once it does, open the Terminal application
5) type the following: cd /Extra 5a)hit Enter
6) type the following: ls 6a)hit Enter
This should give you a list of files of which you will see:
7) if you know how to use vi, then edit the above file; BUT if you do not know how to use vi, you can use pico, type: pico 7a) hit Enter
8) using your arrow keys, move your cursor down to the 8th line that looks like:
Delete the .10.5.6 so you are left with the following line:
9) to save what you just edited, make sure you press the follow control codes in this order: ctrl-o then ctrl-x
This should save the file you just edited.
IF YOU THINK YOU MESSED UP EDITING BEFORE SAVING, then hit the following sequence: ESC then ctrl-x. Repeat the steps starting at STEP 5.
10) verify the change was made by typing the following:
more 10a) hit Enter
Look it over and make sure the mach_kernel line is clean without the numbers.
11) type the following control sequence: ctrl-c
12) exit out of terminal and reboot OSX
This worked for me. I only have OSX installed on my Dell Mini 10V
« Help!! 2 USB Installation | Status of 10.5.8 & 10.6.1 on Mini 9? »
