IMAJF IMAJF is offline
Default System Not Found - 08-31-2009, 09:52 PM
Please see this thread first:
Operating system not found
I pulled the drive and reseated it in case it was loose. When I boot from the USB drive, only the USB drive shows up. I tried to re-install OSX but when I try to partition the drive, which DOES show up in Disk Utility, I get:
Partition Failed:
Partition failed with the error:
Input/output error
Is this a hardware problem?
Dannylivi Dannylivi is offline
Dannylivi's Avatar
Default 09-02-2009, 12:58 AM
Your SSD is most likely dead, you might as well try and re-seat the SSD to see ifs its a dodgy connection but its most probably dead.
« How long can your Mini 9 sleep? | Trying to boot off of bootloader »
