Originally Posted by jp1216 OK, last question. What would be better - a class 4 or 6 SD card or a USB flash drive for data storage/file transfering? I'd prefer an SD card to free up a USB port, but don't want it if it's a lot slower... |
The higher the class the faster the card will read and write, and faster is always good.
An SD card will fit flush inside your Mini 9 and not present the hazard of being broken like a flash drive will.
I'm using a Logitech VX Nano wireless mouse, and the 1/4 inch it's Nano Receiver sticks out from the side is about the maximum I would be comfortable leaving in there all the time. (As it is I'd like to mount it internally, but that's another topic.)
I say go for the best of both worlds and get an SDHC card you can use now.
Augment that with a keychain-style USB flash drive you can use for less critical things when you are able.
