I received my new A90 last week, loaded W7 RC and the Apps I need, and it is running perfectly.
Now I want to establish wide area internet & email connectivity via AT&T, my mobile phone provider. The WWAN location under the bottom cover does not have a connector installed. There is no pcmcia slot, only a SDHC slot, so what are my plug & play options, if any, for establishing an internet connection through my cellular provider? Is there a plug in card that will work through the SDHC slot?
I use an iPhone so I do not think tethering to the iPhone is possible without jailbreaking it which, for many reasons, I cannot do.
