Jazz1 Jazz1 is offline
Default Okay Dell Where Is My 6 Cell OEM Battery? - 05-10-2009, 05:36 PM ... -pictured/
I've search and found aftermarket batteries that all seem to have problems and/or foibles depending upon your firmware version. I see the new Mini 10 gets the love with a 6 cell. I don't want the Mini 9 to look like a humped back whale but there are times when you just need portable power.
catbigred catbigred is offline
catbigred's Avatar
Default Re: Okay Dell Where Is My 6 Cell OEM Battery? - 05-11-2009, 04:02 PM
Course with the 9 with it not having any heat piping the extra lift may be worth it. I've looked at 8 cell aftermarkets which from what I've read don't really work that well. But if Dell created one for the mini 9 I'd buy it in a heartbeat!
SlvrScoobie SlvrScoobie is offline
Default Re: Okay Dell Where Is My 6 Cell OEM Battery? - 05-12-2009, 03:39 AM
the battery works fantasitclly, the bios just doesnt like the battery unless you run a00 like i do, or a04 and live with some blinking lights and a bothersome charging capability
its not so much the battery, as the bios
course they could clone the dell battery to make it work better with the 04-05 bios but what do you want for a Chinese knockoff
Mini 9: Black, WinXP, 2GB GSkill RAM, 16GB STEC SSD, Intel 5300 a/b/g/n, BlueTooth, 8 cell battery (11hr runtime)
AEDan1977 AEDan1977 is offline
AEDan1977's Avatar
Send a message via AIM to AEDan1977
Default 05-12-2009, 02:51 PM
Yea a 6 cell battery would be awsome.
Hey SlvrScoobie that signature is using a massively large font lol?
My Tablet PC: HP TouchSmart tm2 - (Sold My Dell Mini 1010)
System Specs: Intel Core 2 Duo SU9600 @ 1.6GHz w/ 800MHz FSB, 6GB DDR3 RAM, 12.1" LED BrightView Display @ 1280x800, Corsair 128GB SSD, 512MB ATI Radeon HD 4550 Graphics,
Intel Centrino Advanced-N 6200 WiFi Card, Qualcomm Gobi 2420 Mobile Broadband WWAN Card w/AT&T, HP Bluetooth 2.1 Module, Validity Finger Print Reader, HP Webcam
O/S: Microsoft Windows 7 Ultimate 64-Bit
jhillestad jhillestad is offline
Default 05-12-2009, 04:13 PM
I found that running a bigger battery caused my dell mini running os x to slow down over time... I think the time calculation was so messed up it was bogging down the system.... very weird...
« Typical OS X install size? | Mini 9 Boot Up Issue »
