| Senior Member Posts: 169 Join Date: Oct 2008 Location: Iowa | http://www.mvixusa.com/store/index.php? ... escription It is supposed to support Linux. How would get this to work on a Mini 9. Is there a way to force the Mini 9 to use this adapter instead of the built-in Wifi? What about drivers? |
| Member Posts: 59 Join Date: Apr 2009 | looks like a copy of this http://www.newegg.com/Product/Produc...82E16833162030 |
(#4)
| Super Moderator Posts: 883 Join Date: Oct 2008 Location: FAA | viewtopic.php?f=11&t=7177&start=10#p63969 Probably uses the same Ralink OEM drivers as the Buffalo too! ![]() |
(#5)
| Member Posts: 49 Join Date: Oct 2008 | Quote:
OS X Drivers: http://www.mvixusa.com/download/firmwar ... .1.2.4.zip Linux Drivers: Linux http://www.mvixusa.com/download/firmwar ... .0.1.0.zip I'll post how well it works on the 12th when I get mine. -Dravor | |
(#6)
| Super Moderator Posts: 883 Join Date: Oct 2008 Location: FAA | Code: Release History: RTUSB_D2870-1.3.0.0 UI-1.7.1.0_2009_03_10.dmg 1. Sync with VSS. Driver D2870 β V.1.3.0.0 2. Added RT3071/RT3072. RTUSB_D2870-1.2.4.0c UI-1.7.1.0_2009_02_17.dmg 1. Added country region setting function. UI β V.1.7.1.0 2. Fixed add profile from SiteSurvey page when SSID without nothing. 3. Fixed connect to hidden AP from SiteSurvey page and then reconnect to hidden AP without setting profile when radio on. 4. Fixed WPS import two same profile name to Profile page. 1. Fixed bugs of WPS Profile Detail button ( canβt show profile detail data). UI β V.1.7.0.0 RTUSB_D2870-1.2.4.0c UI-1.6.9.0_2008_12_19.dmg 1. Added PID\VID. Driver D2870 β V.1.2.4.0c 2. 2. Fixed warning message when add profile without insert SSID in Adhoc mode. UI β V.1.6.9.0 RTUSB_D2870-1.2.4.0a UI-1.6.8.0_2008_12_04.dmg 3. Added PID\VID. Driver D2870 β V.1.2.4.0a 4. 3. Fixed no security name inconsistent in encryption field. UI β V.1.6.8.0 4. Fixed ComboBox selected bugs (pull down without selecting will set the combobox value to -1). The driver links you posted are rather dated. Judging by the changelog for the latest OSX driver, you may want to consider heading over to Ralink site and updating since there have been quite a few revisions and fixes for this USB adapter. |
(#7)
Considering the prices for some 802.11g adapters it's not bad, my guess is the speeds will not be full 802.11n speeds and the range won't be the same either since it doesn't have huge antenna's on it. Now I just wish I had a white Mini so the adapter would match ![]() It work's fine in OS X, will test Ubuntu next, as well as Backtrack 4 to see if I can use it for Wireless Penetration testing. Pics to follow. -Dravor | |
(#8)
| Member Posts: 49 Join Date: Oct 2008 | MvixUSA now has a How To up for installing the Mvix Nubbin in OS X: MvixUSA : Revolutionizing Portable Entertainment |
(#9)
(#10)
| Junior Member Posts: 9 Join Date: May 2009 Location: Charlotte, NC | I tired it and am returning it, I have ordered the Intel 5300 card with three antennas instead. I tried it in Ubuntu, I was able to connect and after so fun with wireless connection manager was able to connect only on N speeds with the Nubbin (Ralink). I was getting better signal strength and faster speeds on the broadcom B/G card. There is no linux documentation included in print or on the included CD, after contacting support to see if there was an update I missed they send me a link to the source code for new drivers over at the RalLink site, their help pages included info on how to update in OS X but no mention of Ubuntu (or Linux) at all. This card is not worth the money when you can pick up an internal b/g for the same price, and can more easily use those cards with Aircrack-ng and BackTrack. I haven't tried the nubbin in OS X or Windoze, but have been displeased with the results in Ubuntu 9.04 Netbook Remix. |
