mikefsx mikefsx is offline
Unhappy adding wireless antenna - 04-22-2009, 03:30 AM
Hey so which connector the mini uses to connect to the wireless card? MC Card, MMCX, RPMMCX, RPSMA?
I'm thinking of getting 2 of these to for each antenna connector. Here is the website.
davico_rosello's Avatar
Default Re: adding wireless antenna - 04-22-2009, 04:41 AM
u.fl connectors, like these:
these are the other connector type:
on the antenna side, doesn't have any connector, they're just solded:
so you probably will need to cut that end and attach the SMA connector by yourself, or just buy a pigtail large enough to make it trough all the way dow to the card, think 50-60 cm long
FYI, the RP-SMA connector is the big one, not the u.fl one that goes on the card:
sory me no spiko english
« Upgrade Cells in battery for longer life? | SSD going bad? »
