My Dell Mini Forum
Go Back   MyDellMini Forum > Dell Mini 9 Forums > Dell Mini 9 Hardware and Upgrades
Reload this Page Runcore SSD Upgrade Guide (w/Pics)
Connect with Facebook
LinkBack (4) Thread Tools Display Modes
  2 links from elsewhere to this Post. Click to view. (#1) Old
Your friendly admin
Dunhamzzz's Avatar
Send a message via MSN to Dunhamzzz Send a message via Skype™ to Dunhamzzz
Default Runcore SSD Upgrade Guide (w/Pics) - 03-02-2009, 12:59 PM
First of all, why should I upgrade my SSD?
Upgrading your SSD in your Dell Mini 9 will give you an extreme performance boost making using your Mini 9 snappier and overall faster, with the higher-capacity models, you will also get a nice storage boost. Initially it was only possible to get up to 16GB of storage on Dell Mini 9 configurations, and most models only shipped with 8gb, now it is possible to have up to 64GB of storage on your Dell Mini 9.
Why the Runcore Drives?
The Runcore SSDs have been especially made for the Dell Mini 9. Many users have reported some impressive benchmarks with their experiences, especially when compared to the STEC drives supplied with stock Mini 9s. Runcore are also the only manufacturer to produce SSDs of up to 64GB for the Mini 9.
The Runcore drives also feature a micro-usb port for extremely easy drive swapping - without having to reinstall your operating system and programs.
Where can I buy one from?
Online retailer MyDigitalDiscount.com sell Runcore SSDs in 16GB, 32GB and 64GB formats, prices currently range from $69-$219.
Check out the Runcore SSDs on Sale here.
Now for the guide:
Your Runcore package will contain the following:
  • Runcore SSD Drive
  • Micro USB Cable
Setting up your new Drive
You have a decision to make, do you transfer your current operating system to your new drive or install afresh?
If you haven't already at any point - and you have the drivers + recovery disks handy + USB CD ROM Drive - we recommend a fresh install of your original operating system (XP or Ubuntu), Windows XP especially benefits from this, though bare in mind it may take a good 20 minutes or so to go through all the drivers. There are many sections on our forums which go into great depth on how to install other operating systems such as OSX, Vista, Windows 7 and more. Check that you have all the required software/hardware beforehand.
Cloning your Current Drive
If you have chosen to clone your drive (which most users without a external CD ROM drive will have to do) you will need to carry out this step. You will need to install some form of
Click to View Search Results for drive+cloning+software Google: drive+cloning+software
on your Mini to clone your current drive. We recommend using http://www.acronis.com/homecomputing/products/trueimage/, the trial version will be enough to suit our needs for now. The official documentation for this program can be found http://download.acronis.com/pdf/trueimage7.0_ug.en.pdf.
You will need to make a back-up image of your current drive and restore it on your new Runcore drive,the Ruuncore drives very handily connect straight to USB port, simply acting as removable storage, making this step a breeze.
Getting into your Mini 9
(Thanks to acabtp for these images)
Start by turning the Mini over and removing the two screws indicated by the red circles. You will also need to remove your battery.
Use your finger to gently pry the module cover up at this area and pop it out
and remove it
Swapping the SSD
In the picture below I have labelled the SSD and the two screws you need to unscrew to remove it. Simply remove the screws and the SSD will "pop" up, allowing you to unplug it from its slot at an angle.
You will notice the stock SSD has heat pads on it, I recommend trying to remove these for use on your Runcore SSD - better safe then sorry I figured.
Once you have your original SSD in your hand, simply reverse this procedure to fit your new one, place the it in the slot an an angle first, then press it down and screw it in place.
If you have any problems removing your SSD, be sure to have a look at the official Dell service manual for help.
Voilà! Your new Runcore drive is successfully fitted, if you cloned your drive as mentioned earlier, you should be all set to go straight away! Otherwise...
Installing Your Operating System
If you need to install your operating system now is the time to. Connect your USB CD ROM drive to your Mini 9 and carry out whatever procedure you choose to setup your operating system.
Notes
  • Make sure you don't use an even-slightly magnetic screw driver (which is il-advised when dealing with any form of disk anyway) as in removing the screws of the SSD I actually wiped it clean.
  • Also with screws be careful when removing screws not to dead-head them, as then your drive will be stuck in permanently, this happened to me with both the WWAN and SSD!
  • Try selling your old drive on ebay, after wiping it completely.
  • Youtube has some interesting videos of people showing off their boot times with Runcore drives.
Mini 1010 - HD Screen - TV Tuner - [RED]
Mini 1210 - 80GB PATA - 1.3 Webcam - Ice Blue
Mini 910 - Connected by Vodafone - Runcore 64GB - 2GB Ram - Black
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-02-2009, 02:29 PM
I would skip transplanting the heat pads. They're not necessary.
Be sure to use a #0 Philips screwdriver to remove the screws. They have Loctite on the threads and while they are removable, some people manage to strip the screw head in the process. If you use a wrong-size screwdriver you'll probably have trouble.
Mini 9|2GB RAM|64GB RunCore|Intel 5300|Windows 7/Snow Leopard
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-02-2009, 03:11 PM
also,about the 'magnetic screwdriver issue', I took my stock SSD out once with one and never had it wiped clean .I wasnt aware SSDs were prone to magnetic interference like HDDs are...
*Sold My Mini 9*
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-02-2009, 03:34 PM
I agree - a magnetic screwdriver won't affect an SSD at all.
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-02-2009, 09:02 PM
I just got my Mini 9 and installed a Runcore 32GB SSD last week. I was hunting for a guide like this prior to doing it. I pulled it off with no real trouble but would have liked to have seen a guide like this beforehand. Thanks for posting it. I'm sure that many people like myself that don't have a lot of computer knowledge will appreciate it. This upgrade is essential as far as I am concerned as well as a 2GB RAM upgrade.
Your friendly admin
Dunhamzzz's Avatar
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-02-2009, 11:22 PM
Well if definitely affected me, multiple times, I was tearing my hair out over it!
Must have been super-strength magnets lol.
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-03-2009, 03:02 PM
I know there aren't many vendors selling replacement drives for the Mini 9.
But I think you should at least mention the High failure rate of the MDD Runcore drives and the limited availability.
Otherwise this is less of an upgrade guide and more of a sales pitch for MDD.
Also adding links to the other available drives would help.
I believe Crucial and Buffalo make replacement drives? as well as Dell selling them.
DXP DXP is offline
DXP's Avatar
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-03-2009, 03:21 PM
This is great thread.. I save this in my bookmark- I will refer my friends who own their mini 9, they want to go upgrade....
10/20/08:Asus Eee PC 1000HD - PNY 2GB PC2-5300 667MHz DDR2 - 120GB SATA HDD - WinXP SP3-32 bit
08/09/09: Gateway LT3103u - 2GB DDR2 SDRAM - 250GB SATA HDD - WinVista SP2-32 bit - SideWinder X8
Default Re: Runcore SSD Upgrade Guide (w/Pics) - 03-03-2009, 08:26 PM
And don't forget to post the read/write speeds to make clear the preference for Runcore. I'm glad that I got rid of the lag time that my original 8GB SSD had by buying Runcore.
Default Runcore NOT so fast! - 03-04-2009, 02:28 AM
My Stock Dell Mini 9 with 16 GB SSD is faster than the 64 GB RunCore. See YouTube movie for video, showing 25 second boot time (vs. about 30 seconds for 64 GB)!
Here is the link: http://www.youtube.com/watch?v=Rrr9BA8RBf4
Macadell Mini 9 OS X 10.5.6
2 GB Crucial RAM 16 GB Stock SSD
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-9-hardware-upgrades/4283-runcore-solid-state-drive-upgrade-guide-w-pics.html
Posted By For Type Date
Runcore SSD Upgrade Guide (w/Pics) This thread Refback 07-30-2009 01:45 PM
Runcore SSD Upgrade Guide (w/Pics) - MyDellMini This thread Refback 06-18-2009 11:37 PM
Perpetual Netbook Comparison Thread... - Topic Powered by Eve For Enterprise This thread Refback 05-30-2009 04:17 PM
3DCenter Forum - Diskussion Schnäppchen Dell Vostro A90 This thread Refback 05-26-2009 06:04 PM
UMPC Topsites
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
Copyright © 2008-2010 MyDellMini.com. Hosted on a CatN vCluster.
