(#21)
(#22)
(#23)
(#24)
(#25)
| Junior Member Posts: 8 Join Date: Mar 2009 | In RE: replacing STEC with non-usb (Crucial) SSD Well, first off, I'd be careful with the Crucial SSD. Its listed read/write performance numbers are 40 MB/s & 15 MB/s, respectively. All else being equal (a big if), this would be way below the RunCore's R/W stats of 78/44 MB/s, and even below the STEC: See comments at crucial-32gb-ssd-for-mini-9-is-out%C7%83-t2645.html That, and the fact that it didn't come with a usb port, pushed me to pay $40 more for a same-sized RunCore, which was out of stock even, at time of order (I'm still waiting). Clone the drive right out of the box or whether to set up XP first?....well, that's nearly the same thing, since your drive right out of the box (you mean the Mini?) is a clean install (unless you're referencing any extraneous software Dell installed), and if you set up XP first, it's also a clean install (even cleaner). Otherwise.......if you plan to image the Dell-installed OS, first create a backup with the software of your choice (bear in mind previous caveats). If you don't have access to another PC, see (*) below on whether or not you need to build a PE (preinstallation environment) disk first. Then physically replace the STEC with the Crucial. Next, the disk alignment (optional, but recommended). Since you don't have a usb port, the easiest way is to use a Vista recovery disk (yes, you use it even if you plan to use XP as your OS), but you'll need to have an external usb optical drive for this (as you'll see later, it's a necessity throughout these processes). The advantage is that you don't need to use another computer. You can get a Vista disk ISO and instructions here: http://www.ocztechnologyforum.com/forum ... ostcount=3 After that, you can finish by either loading XP manually, using the Dell-supplied XP CD's, or restoring your Dell-installed OS image (which you saved before, right?). (*) I've read that you can restore with Acronis (I guess they have a bootable CD from which you can start up their software). Otherwise, you'll need to build a PE disk, boot off it, and then restore the OS using other software. For previously stated reasons, I recommend DriveImageXML. Links and information for the latter is here: http://www.runtime.org/peb.htm (Follow the links to build a Bart PE disk & add the DriveImage plugin). I've built a PE disk once before, and it was an involved experience. As an aside, I would recommend doing a manual re-install from the Dell-supplied XP disks. All you need are the OS and drivers. You can choose whether or not you want to install any of the other Dell software. Also, it'll save the hassles of the restore, and theoretically, your system is still new anyway, so there's no data or other software to save. There probably are easier ways to get an image onto a non-usb miniPCIe SSD; maybe other members can point out other methods. Notes: 1) I have NOT actually ever restored a system image using a PE disk, so I can't say how easy (or hard) it is to do, 2) When I built my BartPE disk back then, I had an XP Pro CD; I'm not sure if a BartPE disk can be built from the Dell-supplied XP CD, 3) There IS a device into which you supposedly can plug a miniPCIe card, and allows access via a usb port, but it's only available from overseas, costs about $35 (before shipping), and there's NO guarantee that in the end it'll read the Crucial (or any specific SSD, for that matter). http://www.aeneas.com.tw/pdf/mp1.pdf In short, if you need to do OS image restores or disk settings, having that little usb port can takes hours (days, if you're error-prone) off your task 8-) . |
(#26)
| Senior Member Posts: 292 Join Date: Mar 2009 Location: Maryland | Quote:
(#27)
| Founder Posts: 1,855 Join Date: Sep 2008 Location: Hampshire, UK | Quote:
admittedly - I just tore my SSD out so its sitting there with 1 screw hole missing - try it if you dare! | ||
(#28)
| Super Moderator Posts: 5,686 Join Date: Nov 2008 Location: New Hampshire | Quote:
Mini 9|2GB RAM|64GB RunCore|Intel 5300|Windows 8 | |
(#29)
(#30)
| Expert Member Posts: 521 Join Date: Nov 2008 Location: Dislocated | Quote:
but, forget the crucial!the stock ssd is even better! you will be happier with a 16gb runcore in a primary drive speed is everything! :ugeek: | |
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-9-hardware-upgrades/4283-runcore-solid-state-drive-upgrade-guide-w-pics.html | ||||
| Runcore SSD Upgrade Guide (w/Pics) | This thread | Refback | 07-30-2009 02:45 PM | |
| Runcore SSD Upgrade Guide (w/Pics) - MyDellMini | This thread | Refback | 06-19-2009 12:37 AM | |
| Perpetual Netbook Comparison Thread... - Topic Powered by Eve For Enterprise | This thread | Refback | 05-30-2009 05:17 PM | |
| 3DCenter Forum - Diskussion Schnäppchen Dell Vostro A90 | This thread | Refback | 05-26-2009 07:04 PM | |
