Question (NOT RESPONDING) issue please help! - 04-06-2011, 10:12 PM
so when i am using the netbook when i am on the internet or even off just browsing threw some files i constantly get the (NOT RESPONDING) issue that you see at the top of the window what is that caused from? how do i fix that? i have a dell mini 9 2GB RAM 32GB SSD so i dont see why it is doing this someone please help me...
Anthony
Mini 9|2GB RAM|32GB super talent|Snow Leopard
Default 04-07-2011, 01:00 AM
This is Windows' way of telling you that you clicked somewhere in an application's window but it did not process the "message". This could be because the application is hung but most likely it's just that there's too much else going on in the background and the application hasn't gotten the CPU cycles yet.
You can't "fix" it other than by reducing the amount of other stuff going on while you are browsing, etc., and even then you'll see it sometimes.
Default 04-07-2011, 02:09 AM
ok so basicly their is nothing that i can do?
Anthony
Default 04-07-2011, 02:30 AM
Not really. I see this sometimes when my Mini has just booted. It settles down after 5-10 minutes.
Default 04-07-2011, 10:28 PM
oh ok i have also noticed this...thank you
Anthony
scottyd62's Avatar
Default Not Responding Same issue as Anthony - 04-11-2011, 12:35 AM
I have the same issue as you all. I just got this mini 9 second hand from someone that had Linux on it. I installed a Genuine copy of XP on it and upgraded the SSD to a SuperTalent 32GB, and upped the RAM to 2GB. I have no processes running that would cause it and plenty of RAM. When the Not Responding occurs, I monitor my task manager and it is baffling to see absolutely nothing in the process tab that would be causing it. CPU stays at System Idle 99 while the application tab shows the apps not responding. You two are correct, it is the worst when I first boot up, but the problem mysteriously finds it way back after a while. I have worked on plenty of computers, and it is what I do for a living (only 7 years). This one is really kicking my butt. I really can't help but wonder if the Super Talent SSD is causing the trouble. So I spent the last 2 hours painfully failing at trying to install XP on a external hard drive to test my theory. I contacted Super Talent via email and they had me run some read/write test and they emailed back saying that all is well with the test and there was no firmware updates available for the Super Talent SSD. Just curious Anthony, is your Super Talent SSD the FEM32GFDL model?
Scott
Dell Mini 9 / 32GB SSD Super Talent / 2GB RAM / Windows XP SP3
Default 04-11-2011, 12:52 AM
I have a RunCore SSD.
scottyd62's Avatar
Default 04-11-2011, 01:57 AM
I noticed that holmes, makes me really wonder. You never experience the NOT RESPONDING issue after 10 minutes?
Scott
scottyd62's Avatar
Default Researching - 04-11-2011, 10:20 PM
I have been researching some claims that Microsoft dskcache tool will fix the freezing/not responding phenomenon. But I am not able to find the tool for XP....yet. Hope I can find the dskcache tool or if someone knows about it here.
Scott
Default 04-12-2011, 12:49 AM
When Windows first boots, especially on a system that has a lot of stuff loaded, there are a bunch of background processes that kick in, looking for updates, setting up services, etc. Until these complete, the system can seem sluggish. I find that once it "settles down" I rarely get the "Not responding" message. I won't say never, but I can sometimes see that on my quad-core Core i7 system too.
not responding issue help
« Has anyone opened the dell mini Battery? | Upgrade Was a Downgrade? »
