Hi, I am trying to upgrade my Mini 910 with a 32Gb
SSD. The new
SSD has been fitted and I am trying to install the original XP Home Edition operating system by using an external CD drive (brand new) with the original Dell XP re-installation disc.
It appears that the installation is going ok then the computer re-starts and the process just seems to repeat itself without stopping. I must be doing something wrong.
Prompts I get are where to install ie partitioned or unpartitioned space/ NTFS or FATS32. I am not sure which I should be selecting.
I also get a prompt about pressing F6 if I need to install SCSI or RAID drivers - I do not know if I should be selecting this option or not.
So if anyone can assist with simple step by step instructions without using too much techno babble it would assist greatly.
The new
SSD is a Kingspec PATA 32 GB.
Re-installation disc is original XP Home Edtion SP3 . I also have the the original Dell Drivers Disc.Thanks in advance
