Question please help! - 03-28-2011, 01:09 AM
question 1-
ok so for the ram is 2 gb the max and if so do i add it to the existing or do i replace it with the existing?
question 2-
as far as the ssd goes you suggested rune and super talent from a scale of 1-10 how bad is super talent? because i cant find rune in stock..
question 3-
if a take it to a computer installer place will they know what they are doing or not?
question 4-
whats the lowest i should go for ssd if i keep running xp?
i know i am asking alot but this really helps me alot... thank you so much
question 1-
question 2-
question 3-
question 4-
question 1-
question 2-
question 3-
question 4-
question 1-
question 2-
as far as the ssd goes rune and super talent from a scale of 1-10 how bad is super talent? because i cant find rune in stock..
question 3-
if i take it to a computer installer place will they know what they are doing or not?
question 4-
Default mini 9 questions - 03-28-2011, 01:48 PM
Replace it, there is only 1 slot for Ram in the Mini 9, 2gb Ram is max for mini 9, it will not see anything more than that. Super Talent is okay I've had both, in 16gb they seem to me to run about the same, check this forum, I believe you want to get the newer model, I believe you want the model # with the letter F in it, I forget what letter is in the older models. Be sure to double check my info on which is the newer model. You can run a stripped down version of XP on a 4gb, but it is really tight, too much of a pain. 8gb with XP is abit better but I would go with at least a 16gb, certainly a 16gb if it is Windows 7, depends what you want to keep on it, a 32gb is nice, then you have plenty of room. I don't see why any computer shop would not be able to install ssd and load windows for you, it is really simple to do if you have a usb optical drive.
My Flagship Rig: XPS I7 930 2.8ghz 12gb Ram 120gb OCZ SSD ATI Radeon 5830 W7 Ult Asus G73SW I7 2.0GHZ QuadCore 12gb Ram 120gb OCZ Ssd Nvidia GTX460 Dell Latitude E6400 Intel 2.4ghz Core2 Duo 40gb Intel Ssd 4gb Ram
Default 03-28-2011, 02:03 PM
SuperTalent has three generations of SSD. GHDL (1st), GFDL (2nd) and GWDL (3rd). Avoid the GHDL. The GWDL doesn't seem to be available yet.
Default 03-29-2011, 01:03 AM
ok great thank you for the reply i sent it in to a computer shop for them to do it i cant wait
Anthony
Mini 9|2GB RAM|32GB super talent|Snow Leopard
install, ram, ssd
« wifi reception booster | is this a good deal please help. »
