Default help with limux really strange problem - 03-16-2011, 09:37 AM
Hey all i got ubuntu 9.40 installed and ruinning , when i goto "Hardware Drivers I get ""broadcom STA wireless driver" and it says "This driver is activated and currently in use" YET i canot see nor conenct to ANY wireless network help please.
ALso I have an 8 GB SATA PCI-e i wanna swap for a PCI-e PATA drive
Default 03-20-2011, 02:53 PM
Is it failing with just your network? Will it connect at other hotspots?
Dell Mini 9 | Ubuntu 10.04 Netbook LTS | 2 GB RAM | 4 GB SSD | BIOS A04
Default no - 03-20-2011, 11:20 PM
No it will not install the drivers for the network card all the time, when i roboot i have to install the drivers all over again
Default 03-21-2011, 01:31 AM
Are you running off a USB drive? I ask because you said "when i roboot i have to install the drivers all over again", which would be expected if you were running a LiveCD/USB environment without persistence.
« Dell Mini 9 with capacitive touch | wifi reception booster »
