Default Smaller aftermarket charger for mini 9? - 12-15-2010, 06:49 PM
Has anyone come across a smaller charger for the Mini 9? Perhaps a piece charger where the cord and adapter can be disconnected? I've got a really nice bag for the Mini 9 but the charger takes up more space then I'd like.
Default 12-15-2010, 06:57 PM
Someone in this forum found one similar to what you describe, but I thought it was larger than the standard charger. The Mini 9 adapter is already pretty small.
Default 12-15-2010, 11:18 PM
I have an inline "brick" type supply with a detachable cord that I got on Ebay a while back, shortly after I got my mini. It's not really smaller than the OEM wall-wart, but it does fit easily into my Targus netbook bag along with some other stuff. Dimensions are about 3-1/2" x 1-1/4" x 1".
I can't point you to the exact vendor since it was so long ago, but since the Mini uses a standard 19V input there are plenty of adapters available. Of course quality will vary widely, the one I got has been good but there are a lot of crappy ones out there.
eugene's Avatar
Default 12-16-2010, 02:26 AM
The Acer Aspire One (brick style), is supposed to be compatible. If you have a nearby Acer dealer it might be worth having a look.
Default 12-16-2010, 03:22 AM
Reliability of the product is questionable but you might want to take a look at eznsmart adapters.
The link above does not work for some reason. Go to amazon.com and search for "eznsmart inspiron 910"
Mini 10v, BIOS A06, OS X 10.6.6, Linux-Mint, 1 GB RAM, 250 GB HDD
« Fingerprint Scanner Mod | Anyone success change to HD-LCD(1280x800) »
