edioflix edioflix is offline
Default Can a Dell mini 9 charger charge Vostro A90 battery, or vise versa - 05-20-2010, 07:12 PM
I have a dell mini9 and a vostro a90. I checked the batteries on both machine. Although the specs are very similar, they are different model. Question is can use one charger to charge the other machine? That way, when I travel, only need to bring one charger for both laptops.
ElijahRW ElijahRW is offline
Default 05-20-2010, 08:48 PM
Yes you can. the M9 and A90 are the same spec wise, just different colored skin.
Psygnosis Psygnosis is offline
Default 05-21-2010, 07:38 PM
You can swap the batteries too, hardware wise they are 100% the same laptop. The only difference is the name in the bios and the color of the case.
Dell Mini 9:
64gb SuperTalent Double Wide | 2gb RAM | eBay bluetooth | Windows 7
« Best wireless card replacement | How to remove stuck / stripped screw? »
