Question 1: I was wondering if any of the wireless card upgrades for the Mini 9/A90 will increase range/signal strength? I have a really weak signal, it still works, but sometime packets won't send. Do any of the other options increase strength? (Must work with W7)
Question 2: I just ordered a Runcore 32GB
SSD for $120, but it is backordered. Are there any other
SSD options from other companies that have similar speed, or atleast better than the stock
SSD? I would prefer 32GB, but if there is a cheap enough 16GB that offers increased speed, I would look into that as well. I feel like I may not utilize the Runcores speed as much as some of you, so if there are some other options that offer good bang for buck value, I will consider. Thanks in advance!
