indie1776 indie1776 is offline
Send a message via AIM to indie1776 Send a message via MSN to indie1776 Send a message via Yahoo to indie1776 Send a message via Skype™ to indie1776
Default Repeatedly Dropping Bluetooth connection with iPhone 3G/3.0 - 06-27-2009, 01:10 AM
I have managed to work through to a point where I have a working system with OSX 10.5.7 + all updates installed and a working USB tethering solution with an iPhone 3G running OS 3.0.
However with bluetooth it is a little different; I have bluetooth enabled and the system discoverable and I can successfully pair with the iPhone. However when I try to connect I get a connection for a few seconds then it disconnects. At that point bluetooth is off and I have to use BTon to restore it.
Anyone having similar issues or any ideas on what is amiss here?
Black OSX 10.5.7 / 2GB HyperX / 64GB RunCore / 1.3Mpx / internal BT
shdwghst457 shdwghst457 is offline
Default 07-15-2009, 01:08 AM
i too am have the EXACT same issue. i'm assuming we both installed via the dellEFI method? my type11 installed wouldn't work with 10.5.7 but when i switched to using the other method and dellefi 1.2a5, attempting to pair to a 3.0 iphone 3g causes my bluetooth to turn off. do you think it's something related to the phone that's blocking hackintoshes?
sagamax sagamax is offline
Default 10-03-2009, 07:41 AM
any solution for this? I am having exact problem on my 10v on 10.5.8.
« Keyboard/Mousepad dont work except external | Card Reader Issues »
