mgroups mgroups is offline
Default Using bluetooth for external audio bypasses Realtek Sound Manager - 06-21-2009, 04:37 AM
When I play audio on an external stereo via my USB bluetooth device the Realtek Audio Manager is bypassed, that is, the Realtek equalizer and other controls don't work. I would like to be able to use the audio manager while using bluetooth. Is there any way to do this? If I were using an internal Dell bluetooth device instead of the USB device would it still bypass Realtek? Any help would be greatly appreciated.
Offroadie Offroadie is offline
Default 06-21-2009, 04:17 PM
Doubtful the internal Dell unit would make any difference as it's also a usb unit. I also doubt there is a way to use the Realtek manager as you're not using the on board audio but the Bluetooth stack for audio output.
audio, bluetooth, external, realtek
« Brightness Problem after Bios A05 upgrade | Bluetooth stoped working, OSX »
