| Junior Member Posts: 2 Join Date: Jul 2009 | have you tried the patches for the built-in bluetooth? If you go to the Apple logo and click "about this mac" it should give you the vendor and product IDs. Then you can make sure OS X knows the product and vendor codes. They will likely need to be converted from hex to decimal. There is a good tutorial on this site that teaches you how to go in and update the IDs. I don't know if this works but let me know... http://www.mydellmini.com/forum/mac-...nal-mod-3.html About halfway down the page there is the tutorial. But you will need to use the code for your particular bluetooth chip instead of the ones that come built into the machine. Good luck! |
(#4)
(#5)
| Senior Member Posts: 291 Join Date: Apr 2009 | Triple Boot: Windows 7 | OSX 10.6 | XP |
| Tags |
| bluetooth, osx, sleep, usb |
