  (#21) Old
beekeep beekeep is offline
Default Re: Resolution problem - 11-09-2008, 04:47 PM
After giving up on the constant icon reshuffle, I unchecked "Show Desktop Icons." The net effect, however, is that my mini 9 no longer bothers to change back to 1024 X 600. When I turned the icons back on, and restarted, it once again went through the 800 X 600 to 1024 X 600 procedure. Strange!
  (#22) Old
Thallid Thallid is offline
Default Re: Resolution problem - 04-01-2009, 02:20 PM
I had the same problem...
I just fix it by downloading drivers from Intel site... then applied my previous saved theme and it worked
Note: the new drivers didnĀ“t allowed to set 1024x600 but when i applyed the old theme the resolution appeared to set as 1024x600
It worked with me...
« Upgraded Linux to XP - Unknown Device | CD Boot Problem »
